1998 v 70 awd p0117/p0116
i have had both of these check engine codes pop up in the last few days. i replaced the etc on the thermostat twice now with a slightly used sensor i knew was in working condition and a brand new sensor. I am still getting the engine codes so what else could i do to fix this
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Did you use OE parts? These are usually pretty reliable codes...
I have had new KAE temp sensor in our n/a for two years and it hasn't given me a problem, but I also flushed system and replaced thermostat with a new Wahler one the time of install. Make sure you clean the electrical connector with electrical parts cleaner.
If I recall correctly: I installed pieces, cleared codes, and then had to "lawnmower" start her up. Car wouldn't start otherwise.
Retired:
2015 Volvo S60, T5, 85K
- 37 Replies
- 8562 Views
Last post by songzunhuang
- 904 Views
Last post by Vancethevolvo
- 2387 Views
Last post by mar601
- 1639 Views
Last post by dr1vereye
- 1644 Views
