Hey all,
So a weird one today.. I'm reassembling after changing the a/c evaporator and can't figure out where the turn signal/cruise/high beam plugs in. I have the harness coming off the stalk, going to about a 2 inch cable in the steering column, then can't see anywhere to plug it in next. Can anyone assist?
Thanks
99 s70 Where does the turn signal plug in Topic is solved
Thanks cn90. I looked again and it is plugged in properly, there is just another connector that comes off the signal which is disconnected, but I believe it isn't supposed to be hooked up to anything.
Any suggestions what to check if my signals turn on when I use the hazard light switch, but not when I use the signal light switch? Also the high beams aren't working
- Been thanked: 504 times
I posted the DIY for the Clockspring a while ago, in that DIY, scroll down to step #8 to see the Turn Signal Stalk setup:
https://volvoforums.com/forum/volvo-v70 ... nit-48052/
Legend!
The pic in step 11 showed me what's wrong. There's actually TWO cables on the signal stalk. I had one plugged in, and the other had bent backwards toward the firewall making it look like something under the dash connected to it. Turned that connector around and it plugged right in.
Thanks cn90!
Thanks cn90!
- 8901 Views
Last post by rhubarb
- 3043 Views
Last post by Roger_850T
- 1786 Views
- 3889 Views
- 1069 Views
Last post by kyngofpop
