2005 S60 a/c condenser o-rings
asummers
Year and Model: many
Post by asummers »
Hello,
Does anyone know the part number for the o-rings at the pipe that joins to the condenser? I have determined that to be my leak point and would like to get new o-rings in hand before I take the front end plastic off the car.
Thanks.
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
You want to inspect the connections for corrosion before you order parts. If either of the surfaces that the O-rings seal against doesn't look shiny and like new under a magnifying glass just replacing the o-ring isn't gonna fix you up.
To answer your specific question P/N should be 6847526. You'll want to place your order with a phone call and have them verify this is the correct O-ring for that location.
asummers
Post by asummers »
I checked the connections to the condenser, it was a loose screw-in sensor that goes just above the hose connection. Tightened it up, recharged the system...still working great! Thanks.
mrbrian200
...and with summer temperatures getting steamy 1000 Volvo owners suddenly feel the need to go out to the car and check something...
