I have two each of brand new inner and outer tie rods and sway bar links bought for my 1998 V70 AWD. The outer tie rod ends are TRW OE and the other two sets are genuine Volvo in original packaging. Part numbers are- outer tie rods 271598OE and 271599OE, inner tie rods 3546266T, and links 31212730. Two steering rack boots are also included- PN 270597. Original cost was about $275. I'll take $200 plus shipping for the lot, or inner set- $50, outer set- $70, links set- $90, boots set-$10, all plus shipping. Paypal only.
I also have a used Volvo fuel pump for this car- the pump itself was still working when I removed and replaced it, but when I took it out, I found the external wires to the level sensor were broken off where they go through the pump cover. I also cut off the pump wires at about 4" above the cover. I checked the level sensor using the internal wires and it seems to have the right resistance. I think the feed-through could be repaired fairly easily. Since the new Volvo pumps cost more than $400, I thought someone might be interested in repairing it. I'm not sure what price to ask. If anyone is interested, either reply or PM me.
Tie rod sets and sway bar links 98 V70 AWD
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
