Hi,
I am looking to get a Single Dim Radio to replace the factory radio cause I want to be able to have the option to reinstall the factory radio at a later time. When installing the new radio, a couple of posts I have seen mention the connector pins needing to match up. Is each after market radio plug different? I basically just want to have the option for siriusxm in the vehicle (the reason for the upgrade). If there is a specific after market radio that you recommend that installs easily in the 850R, please let me know. Also, if I need any other additional accessories.
Thank you.
1996 850R Single Dim Radio
Teddy1975
- Year and Model: 2007 V50
- Has thanked: 1 time
- Been thanked: 7 times
Most after market radios follow an ISO standard, which means you can use this harness to hook it up without having to modify the wiring harness in your car:
http://www.ebay.com/itm/ISO-Radio-Adapt ... 1685026146
I'll recommend getting a Pioneer head unit.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Agreed, it's pretty slick installing aftermarket radios with ISO connectors using a pre-connectorized
adapters like the one linked above, but many ship with a permanently attached, bare-ended wiring harness.
Fortunately, nearly all aftermarket radios are supplied with an ISO color coded wiring harness, just like the
majority of car specific wiring harness adapters. You can easily connect by color - Here's an example from Metra:
http://www.ebay.com/itm/Volvo-Car-Stere ... -Y&vxp=mtr
There are also some kits out there that include a pocket for the empty single DIN space:
http://www.ebay.com/itm/VOLVO-CAR-STERE ... ZM&vxp=mtr
JRL
- Year and Model: Several
- Been thanked: 16 times
You also can just install USA SPEC or a GROM unit for less than a good aftermarket radio and you will have the connectors for a Satellite radio!
These use the CD CHANGER out plug
- BEJinFbk
Actually, the CD Changer INPUT connector - Potato, Patoto...JRL wrote: 03 Jul 2017, 17:15 You also can just install USA SPEC or a GROM unit for less than a good aftermarket radio and you will have the connectors for a Satellite radio!
- aewoodhouse
- Year and Model: 2007 V70R
If you order the head from Crutchfield, they generally include the model specific harness adapter and 1U pocket for free. Just installed a 1U Pioneer MVH-X390BT in my 2000 V70XC in all of 15 min. Very nice helpful people there too.
2007 V70R
2004 XC70
Past:
2009 C30
1998 S70 - Turquoise 5 speed
2000 XC70
2004 XC70
Past:
2009 C30
2000 XC70
- 2985 Views
Last post by 960 Tank
- 1417 Views
Last post by Ozark Lee
- 2337 Views
Last post by doublebug
- 16 Replies
- 16906 Views
Last post by firstv70volvo
- 1240 Views
Last post by Thenextman
