Marking "Topic Solved" is functional again. It's the green check next to your post. BTW, please do use this when your question is answered and verified. Thanks!
E-brake doesn't work...
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 443 times
- Been thanked: 1339 times
Re: E-brake doesn't work...
Je vous en prie
Link To Volvo Glossary
- Year and Model: 1998 Volvo V70 XC
Thanks so much found the star nut adjustment screw in the console access door.... works pretty darn good... about 10 turns did the trick:)
Thanks for the write up.
I know this is a rather late addition to an older post, but I have a note to add that may help some folks. (I acquired my volvo in May of 2019)
On my 1999 V70 XC AWD, there is no dedicated adjuster hole to access the toothed adjustment wheel. Instead access is via the lug bolt holes. The adjuster wheel is not at the 12 O'clock position. On the passeger side, the adjuster wheel is at about the 3 O'clock position. On the driver side, it is at about 6:30 to 7 O'clock position.
That’s a bit bizarre, as the design I’ve seen on my 1999 FWD has the two adjuster wheels only about 5 cm apart on a common tube. Is the AWD parking brake setup different in are there funky parts here?RocBar wrote: ↑Fri Jan 03, 2020 7:12 pm Thanks for the write up.
- Has thanked: 52 times
- Been thanked: 201 times
I don't remember where the adjustment cylinders were on mine, but I believe they were still at the 12:00 position on my car. There are not pass through adjustment holes on the rotors though, you need to remove them to adjust the cylinders.
00 V70R Venetian Red/Charcoal M56 Swapped 200k
03 S60 2.4T Silver/Black 118k
07 XC90 V8 AWD Sport Titanium Grey/Black 174k
92 245 Base White/Beige 249k
98 V70 GLT Black/Beige 205k
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
00 S70 GLT Mystic Silver/Taupe 253k
91 944 Turbo Dark Green/Beige 175k
93 944 Base Beige/Beige 221k
98 S90- Silver/Gray 207k
95 850 GLT Tropic Green... crushed
01 S60 2.4T Black/Black 230k
88 744 Turbo M46 Beige Metallic/Beige 188k
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
I didn't pull the rotors to look at the parking brake parts / setup; I was only trying an adjustment. When I went to do the adjustment and the instructions in this thread didn't seem to appy, I did some hunting around elsewhere on the internet and found a reference to the star wheel adjusters being at different positions and needing to access them via a lug bolt hole. I don't remember the source and I can find a bookmark for it. But at least it seems like the setup is stock. The fuel filter placement and access to it is different than in any posts I've seen too. So it looks like volvo made some changes when it designed this first gen AWD.abscate wrote: ↑Sat Jan 04, 2020 4:00 amThat’s a bit bizarre, as the design I’ve seen on my 1999 FWD has the two adjuster wheels only about 5 cm apart on a common tube. Is the AWD parking brake setup different in are there funky parts here?RocBar wrote: ↑Fri Jan 03, 2020 7:12 pm Thanks for the write up.
- Has thanked: 22 times
- Been thanked: 302 times
The AWD and FWD parking brake systems are similar but different. RocBar is correct. The adjustment for the parking brake is done through the lug bolt holes. I had to tell a dealer how to do this as they did not know!!
The parking brake cable on a FWD access the rear brakes from the front of the back plate behind the rotor. The AWD parking brake cable comes in perpendicular to the back plate behind the center point of the rear axle. The way the parking brake operates is also slightly different inside the rear rotor hub. It is more complex.
They both suffer from the same issues. The lack of maintenance and the outer and inner cables seize when the outer cable splits where it mounts just forward of the rear wheel on a FWD car and where the cable is mounted on the rear subframe just forward and inside from the rear wheels.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
2006 XC70
My indie saved me gobs of pain one year on inspection when he saw the split happening, lubed , and then resealed with tape and RTV
- 9 Replies
- 743 Views
Last post by Niamhsdad
- 401 Views
Last post by FLXC90
- 277 Views
Last post by gearjammer9888
- 205 Views
- 2847 Views
