Help needed quick... I was replacing the A arm on the passenger side and somehow the hub / rotor assembly got partially pulled out of the transmission during the work. The splines from the half shaft are still engaged in the transmission - I can turn the rotor and hear the transmission make noises. How do I push the half shaft back into the transmission?
I hate to use the word urgent, but the wagon carries my wife's wheel chair, and I need to get the v70 today..
re- inserting halfshaft
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
The circlip needs to compress a little before it will slide in and lock to place. Wiggle it around in a circular motion while tapping it modestly with a rubber mallet and see if you can get it to work in. If no luck with that approach give it a good hard whack, but be mindful to use something between your mallet and the inner joint to distribute the force across several inches so as not to damage the boot. You can easily punch a hole in the boot if you're not careful at which point it all has to be pulled off the car again.
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
The circlip is under the inner boot? Do I need to separate the half shaft from the hub/ rotor assembly?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
Thanks. Job done - the bearing came out of the inner hub, so it was just a matter of rotating the half shaft and pushing it back in...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
That I had no problem with. Another question, though, how much grease should be in there? Everything was well coated with grease, and the grease looked clean. I suspect the PO replaced the inner and outer boots, too they were in near new shape.
I'm not confident with that jubilee clamp. I got it back on and clamped it back down with dykes and it looked secure enough... I would have replaced it with a zip tie if I had one long enough, so I'm thinking about getting some long zip ties and replacing the clamp.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
MarcM
- Year and Model: 2005 S60 2.5T AWD
- Has thanked: 1 time
- Been thanked: 3 times
When replacing mine, I used a socket over the end of the outer spline... held shaft so it was straight-on... gave it a whack-a-doo with a 6# dead blow. POP! in it went.
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
IPD mods:
- 2314 Views
Last post by fasteddyT5
- 576 Views
Last post by SonicAdventure
