I changed my rack and now there is no power steering at idle. Rev to 2k and it returns. It leads me to believe that there is something at play that allows/assists/adjusts power sterring at idle rpm. Like something (a valve) is either stuck open or closed preventing proper function only at idle when the ps pump pressure is weekest.
Despite rack issue this was not an issue prior to rack change. The rack was changed because it was seized up, you could steer but there was no automatic return to center while rolling. Basically if you moved the wheel slightly left while driving it would just stay exactly there.
Trying to determine if I got a bad rack or if there is something else in the system that suddenly failed/clogged... Rack is a rebuilt by MAVAL from FCP.
Power steering issue. No power assist at idle.
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
Have you checked your power steering fluid to see if it is at the proper level?
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Maybe the problem was the pump all along.
Mechanics often change everything out, pump ,rack and all pressure lines. Less comebacks.
I'd snag a cheap pump from salvage or ebay, try that for starters.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Other than swapping out the rack, did you have any other system components disconnected? ie, is it possible the reservoir is plumbed backward such that the pump is pulling fluid off the top rather than the bottom? (I don't know if the hoses would even connect that way.) Also, could the belt be slipping on the pump pulley when at idle?
- jonesg
If no-one has a definitive answer then you're left with a guess, choose either the rack or pump.
I would guess at the pump for these reasons, its easier to swap out, its cheap and its unknown condition.
- 12 Replies
- 4457 Views
Last post by lntravler
- 2498 Views
Last post by br0dy519
- 3273 Views
Last post by chittychittybangbang
- 609 Views
Last post by precopster
- 1030 Views
