P/S Pump - 11 Bar vs 12 Bar
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
My wife's 2005 S80 has a rather noisy P/S pump. The tag on the pump says it's rated at 12 bar. All I could find at the Pick-n-Pull yards are 11 bar pumps so I grabbed one. Would it be OK to swap out the 12 with an 11? I suspect that either pump supplies more than enough pressure under normal circumstances but are there any P/S experts in the house that can offer opinions?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Check well as there are two models with different pulley diameters. Most of the times noise is from wrong fluid or loosen pipe connection at the pump or reservoir (or even something stuck inside the reservoir if it's the old type with the return line near the top) allowing the pump to suck air.
chrism
I don't have the car here right now so I can't compare pulley sizes. I'll be mindful of that when I get into it. I'm certain the fluid is topped up and all the hose connections are tight. The age of the fluid is a bit of a concern though. Since I was going to flush it anyway I will probably go ahead and do that first before removing the old pump just to see what that does. I'd be surprised if that alone quiets the pump but hey I've been wrong many times before.
Thanks.
Thanks.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
It think it makes very little difference, my pump was also making same noise and i swapped it which fixed it. I prefer heavier steering so i would choose 11 bar.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- 10191 Views
Last post by SuperHerman
- 2158 Views
Last post by precopster
- 569 Views
Last post by alschnertz
- 15 Replies
- 5146 Views
Last post by RussB
- 42 Replies
- 12012 Views
Last post by Maestrours
