MVS-Amazon link helps MVS!
XC70 Climate Control Temperature Sensor - Replace or Repair?
2001 - 2007 XC-70
Has thanked: 443 times
Been thanked: 1336 times
Re: XC70 Climate Control Temperature Sensor - Replace or Repair?
1999-2000 are the "bastards"
2001- is P2
A late calendar year 2000 build will be a P2
Link To Volvo Glossary
Ms242245V70
Year and Model: 01V70T5
Post by Ms242245V70 »
I soldered the thermister wires at the tips and my thermister is now working. Ordered a new one from Mouser anyway. 2001 v70 t5
DavidGP
Year and Model: 2005 XC70
Post by DavidGP »
Im trying to solve a similar issue....when I opened my CCM I found the resistor just split in two...isnt it supposed to have an actual resistance between the two wires?
Resistor
Resistor
That is a very high value resistor.
I don’t know if you can use a junkyard CCM but I would certainly try
DavidGP
Post by DavidGP »
Actually dug around the forums for a good hour and found out that people replaced/fixed this issue by getting a NTC Thermistor with similar values to fix the issue. Going to give it a shot this week, only 10$...
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 13 times
Been thanked: 17 times
Post by firstv70volvo »
CCM notes and photos, includes thermistor replacement.
https://app.box.com/s/8m779rkh2pdglnxtcv69nsyhmnm8x1dt
DavidGP
Post by DavidGP »
Thanks :-) I already took everything appart though but that guide would have been usefull while doing it. Not that hard of a job but I guess Ill clean out the little fan while Im in there. Got my part on amazon, was 10$ for 100 NTC glass thermistors while a 10k value so technically should also work with plenty of spares...lol
Been thanked: 164 times
Post by cn90 »
My 2005 XC90 2.5T with 120K miles ...
In the process of cleaning the little vent (where the cabin sensor is located as in the video below), I damage the sensor. So far no issues with heat etc.
What do I need to do?
- Leave it alone?
- Is the sensor that crucial?
- Is the sensor available somewhere?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 322 times
Post by oragex »
Broken thermistor will cause things like no rear windshield defrost, no heated seats, fluctuating or incorrect cabin heat - at least in auto mode, perhaps some more. The faster way is a walk to the junkyard, and undoing the black plastic piece that is housing the thermistor. I believe you can also get the sensor aftermarket (try to google the specs, perhaps 10kohm but needs other specs as well) however not sure how accurate or sensitive a cheap chinese one would be, so perhaps need to go with a good brand. The small fan behind the CCM will also be quite clogged. I made another video with more details accessing the thermistor
Post by cn90 »
Thanks,
There is an ebay seller selling the Thermistor for Volvo HVAC panel.
Already bought it.
Will install in my 2005 XC90 this weekend and report back.
PS: The radio for XC90 is one BIG piece, so it is a bit different than S60 HVAC panel, but the idea is the same...
