Alingment of cams Topic is solved
- SuperHerman
- Been thanked: 207 times
By move do you mean they moved a few teeth or moved as a rotation?
If they moved just a tad put the plastic timing cover on and line up the marks.
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
There are a couple of videos on YouTube. It gets a little more complicated if you have the Variable Valve Timing (VVT) - some Volvos have it on the intake, some on the exhaust, and some on both. But it's still pretty straightforward. If you want to be really meticulous about it, you can buy the tool to lock the camshafts at the back end, and make sure they stay where they need to be. If you are just changing the timing belt, without further disassembly or parts replacement (i.e. not disassembling the VVT hubs,) then you can probably get by without the tool and just set the marks to the right place.
Hope this helps!
Roger
Hope this helps!
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Did you separate the sprockets from the camshafts or did they simply rotate off of their timing marks? If the sprockets were never loosened from the shafts then getting it back in time is a piece of cake - no special tools required.
Also, what year is your car? The timing reference marks moved to 12:00 for both cam sprockets like somewhere around 2001???
- 545 Views
Last post by JimBee
- 437 Views
Last post by Brucebo
- 1110 Views
Last post by dynamaniac
- 20 Replies
- 5469 Views
Last post by dikidera
- 21 Replies
- 4377 Views
Last post by Mabes101
