Shifter skipping
mydamnvolvo
Year and Model: Lots
Post by mydamnvolvo »
Gear selector skipping neutral, car shifts into neutral, but shifting to reverse from neutral slams the car into reverse. You have to wiggle the shifter into neutral as it indicates reverse in the neutral position. Also, reverse lights don't come on. Help?
-Cynthia
Current:
00 V70 (Daily)
01 V70 (Trips)
94 300zx (High School Present)
01 V70 (Hub)
08 GranCher (Daught)
01 740iL
09 C40 (Son)
Former:
93 BMW 525i-Daugh's-Seized
02 Chrysler T & C-Kid Hauler-Fire
72 Buick GSX-Dad's-Corroded
76 Golf GTI-Mom's-Died
97 960-1st-Timing
Has thanked: 1610 times
Been thanked: 4068 times
Sounds like a PNP switch problem, but since I don't own any slushers Ill wait for the experts to chime in..
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
PNP switch is what I thought too.
The action of your shift cable rotates the elements of the switch. There's a central nut on 'em which can loosen. I've seen pictures of them disassembled.
Go out and feel yours while someone runs the selector through its range.
Also, you can remove the 2 bolts on the shift cable and give the cable a tug and go through the selection range as you would if you were in the car doing it.
After removing the 2 bolts pull the cable towards the firewall.
Do this exercise on level ground.
