'99 S70 Base, FWD, Auto -- Whistling Sound-- AC?
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I know the high pitched electronic whistling sound of the throttle body.
Since A/C recharge by local independent, I get a high pitched whistling for between 4 and 8 seconds (approx.) whenever I first engage A/C or when I shut off A/C.
Any ideas as to what this might be attributable (and please don't say: "The A/C system")? It is definitely not the throttle body singing.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 1609 times
Been thanked: 4063 times
My Beetle has done this for three years. High frequency stuff usually means little damage
:-) ( there actually is scientific basis for that statement)
A little resonance in the compressor as it pumps up the high pressure side, perhaps?
With your awareness skills, just monitor for change and enjoy your AC
On edit...and if I had your comprehension skills I would have caught this
Happening on shut down too...almost certainly confirming a flow resonance somewhere , not to worry
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
My 95 has done that for years. Still working like a charm. Just to prove abscate's statement. Also, he is a mod, hence he's always right...
1996 855 R,
2010 V70 D5,
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Semi clogged Orafice tube?
Only when the AC is turned on? A clogged breather makes a non turbo whistle
E Showell
Post by E Showell »
Breather?
'95 855 auto (sold)
Has thanked: 2196 times
Been thanked: 1850 times
Have you tried to use a piece of tube or a stethoscope to listen for the location on the noise? You will need the help of an able assistant to activate and deactivate the A/C.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Mine has whistled on shutdown since I got it in'05.
Blows snowflakes - I have officially moved on. 8)
