P0325 After PCV Heater Hose Mod
charleskennedy23
Year and Model: 1998 V70 T5
Post by charleskennedy23 »
Hi Friends!
I drive a 98 V70 T5 and I recently did the PCV heater hose mod after breaking the PCV hard pipe. I got everything put back together and now I am getting the P0325 code for the knock sensor. I did remove the knock sensor while I was replacing the PCV hard pipe so I believe that I may have not re-installed the knock sensor at the right angle. So I have two questions:
1) how bad for the car will it be to drive around with the knock sensor not functioning properly? I typically run 93 octane fuel in the car.
2) Do I need to plan on replacing the knock sensor or is the issue really as simple as making sure the sensor is turned at about a 92-93 degree angle per Robery DIY's video on you tube (
thanks for the help!
ck
Charles Kennedy
"HAGRID": Black '98 Volvo V70 T5
Has thanked: 1610 times
Been thanked: 4067 times
They take hardly any torque, so watch that wrench when reinstalling.
Alldata says 20Nm or just a wrist twist tight
That being said, this is one of those codes that almost always leads somewhere else.
