Have an issue with no power until engine warms up. Had codes for O2 sensors, replaced all four seemed to run fine for a couple of hundred miles now when engine is cold there is no power, almost like the throttle is blocked. Once it's warm it runs fine. No codes now.
Any help would be appreciated.
Thanks
2001 S80 lacks power until warm
- SuperHerman
- Been thanked: 207 times
What is mileage and engine? Any codes?
Have you checked fuel pressure? What is condition of fuel filter and fuel pump?
Check your throttle body connections maybe something is broken or loose. With heat things expand and you may have an intermittent connection. Also fuel pressure may build enough to overcome blockage. Just easy ideas to look at.
- SuperHerman
Also look at your coolant temperature sensor and thermostat. These are temperature dependent.
- 1471 Views
Last post by cniceiam
- 577 Views
Last post by mndave
- 382 Views
Last post by goldmandan
- 20 Replies
- 4227 Views
Last post by Kjmike95
- 591 Views
Last post by rspi
