Check engine rough running and no power
After i changed my front cam seal on 2001 v70 and setting timing from scratch my car started and ran great. I put it all back together performed test drive. All was great. After shutting off and then restarting the engine ran rough and check engine light came on. Scanned for codes, p0014 came up exhaust cam over advanced. My question is can I just pull the belt of the exhaust cam pully and realign? Or how can I set it without pulling it all apart again if that is possible?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Lets see, accessory belt, timing belt cover, shift the PS reservoir, coolant bottle can be unplugged and shifted.
Removing the cross brace might be necessary.
looking down you can see the crank mark.
then look at the cam sprocket marks.
If everything looks good I would remove the rear cam sensor covers to make sure the cam shaft slots are lined up.
Its not that bad of a job. Probably don't even need to remove the wheel.
Small vice grips can be used to clamp the belt to the intake sprocket to keep it tensioned whist you adjust the other sprocket.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Umm. It ran perfect for a test drive, then was out of whack and ran rough after stopping/restarting. You need to double check the timing belt tensioner and the VVT hub to cam bolt torque while you're back in there. Don't start/run it again until you determine what moved and why.
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
I agree, it sounds like something moved. I am dealing with the aftermath from someone doing that, in my case they forgot to tighten the crankshaft nut, and eventually the crank timing gear wore and moved. It was a bear to find. As much of a pain as it is, I would meticulously check everything. Maybe the cam gear wasn't tight enough. Maybe the sprocket on the cam gear. Maybe the tensioner was loose and the belt jumped a tooth somewhere. Especially since you got a CEL for the cam position.
Also, I don't know what you were using for a reference to do the timing, but there are two versions of the procedure floating around, and the first one (out of VIDA before 2014) is confusing about clockwise and counterclockwise and which way to turn the gears. I don't have the link handy, but look for it, and verify that the confusing language didn't get you.
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
Jwgould-did you preload the cam gears before putting the belt on? Your car has a variable valve timing system that means the cam gears move relative to the cam shaft. It is slightly more complicated than lining up marks like you do on the 1998 and earlier models
Good news is if you didn't do this...
It's almost certainly the fix
It won't cause damage
- 526 Views
Last post by Jwgould1
- 4186 Views
Last post by earthworm
- 1294 Views
Last post by CorgB
- 11 Replies
- 2990 Views
Last post by oldironsights
- 160 Views
Last post by KptnChaos
