Remote Control strange behavior
geminiys
Year and Model: XC70, 2005
Post by geminiys »
My Original Remote Control for XC70, 2005 worked fine until battery died completely. I have replaced it with a new one and now I have to push 'Lock' and 'Unlock' buttons 3 times to have it do what I need to do. Is there anything I can do to have this fixed or 'Stealer' reprogramming is required? Thanks
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
Most likely chip in the remote control broken. Need to prepare and replace chip, or program new remote control.
geminiys
Post by geminiys »
Thanks for reply.
If chip (I assume you are referring to IC - Integrated Circuit) is broken, why does it work at all? It works, except I have to push a button 3 times for it to take an effect. I could be wrong, but I think something else is going on here.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
geminiys wrote: 04 Aug 2017, 10:30 Thanks for reply.
Try removing battery and cleaning contacts.
I often have to push mine a few times, it seems to work better at a distance than close up.
It always works so I don't bother with it.
yagger
Post by yagger »
This chip has eeprom inside. There are many bits like 0 and 1. If some bit froze to some position lake 0 or 1 all time, you can get valid pattern every 2, (every 3,4,5,6...). Depends from frozen (broken) bit inside.
