After replacing the Brake Position Sensor on my 2003 Volvo XC90 2.5t AWD with 250,000 miles (which is located on the Brake Booster body) the car issued a 'Brake Assist Service Required' warning and a code P0573 (OBDII) which translates in Volvo code to-- ECM-900C -- Brake pedal sensor -- Signal too low . Also, the cruise control stopped working.
Others in this forum have noted that this means that something is wrong with the Brake Position Sensor. In my case, it was a loose electrical connection where the car's electrical fitting connects to the Brake Position Sensor's electrical connector.
XC90 2003 2.5t AWD - Brake Assist Service Required Simple Fix
- 35659 Views
Last post by mrbrian200
- 18 Replies
- 6458 Views
Last post by BEJinFbk
- 21 Replies
- 2150 Views
Last post by MrAl
- 4555 Views
- 13058 Views
Last post by nsjames
