N/A Cams in T5 engine
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
So I plan on digging into the head gasket next weekend with the project car. Is it worth picking up some n/a cams while I have everything torn apart or should I just leave well enough alone? I'm leaning towards leaving it as is, but if the consensus is the n/a cam swap is worthwhile I'll take that option. Any thoughts or opinions would be greatly appreciated.
shaker_chi
I do not. I have read a few things on volvospeed about it, but looking to see if anyone has some "real world" experience with the swap.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
RSPI? I seem to recall him running them in his wagon. (along with intake and throttle body) I remember 4 degrees retarded for one of the cams. That's a spec for your tuner though.
I know he has a video for it, and he is in the middle of posting on an S70 in progress at his favorite Chicago parts providers.
Current Volvos:
- Has thanked: 316 times
- Been thanked: 531 times
He has a few videos on it. In fact, he just posted one today or yesterday. I would ask him, because I know he's done it a few times.FLXC90 wrote: 07 Aug 2017, 10:47 RSPI? I seem to recall him running them in his wagon. (along with intake and throttle body) I remember 4 degrees retarded for one of the cams. That's a spec for your tuner though.
And while we have this thread going, does anyone know anything about N/A cams in a GLT? Just curious, because I've heard that it won't work from some people, and others say they will.
shaker_chi
Since the GLT uses a 2.4 liter motor, isn't it just the normal n/a motor with a low pressure turbo? I would assume it may already have the n/a cams. Not 100% on this though.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
I think ardideas.com lists timing retard for the na cams in the ecu tune section
1996 855 R,
2010 V70 D5,
2010 V70 D5,
PeteB
- Has thanked: 57 times
- Been thanked: 11 times
I'm asking for duration, lobe center, and lift.
Duration is sometimes spec'ed from open to close and others from slightly cracked at each end.
I used to know the timings for quite a few Alfa Romeo cams off the top of my head.
No, the GLT engine is the same as the T5 minus the pistons, which makes it a 2.4 and raises the compression ratio from 8.5:1 to 9:1. Although I'm not 100% sure the difference between the turbo and the N/A blocks, or the difference between the heads and cams on the GLT vs. T5. I really wish we had all this information easily available in one place...shaker_chi wrote: 07 Aug 2017, 13:07 Since the GLT uses a 2.4 liter motor, isn't it just the normal n/a motor with a low pressure turbo? I would assume it may already have the n/a cams. Not 100% on this though.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Some people see gain with n/a cams in their T5 engine, some people sees loss.
Personally, if you can't tune (able to change fuel/spark in the ECU) your car, I would leave it stock.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- 545 Views
Last post by JimBee
- 437 Views
Last post by Brucebo
- 1110 Views
Last post by dynamaniac
- 1250 Views
Last post by chrism
- 21 Replies
- 4376 Views
Last post by Mabes101
