trim on wagon hatch
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 97 times
Been thanked: 4 times
Post by loveMy850 »
someone slammed shut my hatch door, WAP! the trim around the back window clips broke off, I don't know what to look for, I can only find repair kits for the lower half of the hatch back door, what do I look for is the clips the same for the rounded trim that drapes along the window, help, it hangs there.what is the name of that piece around the window? Please help... Thanks
Has thanked: 2210 times
Been thanked: 1852 times
Can you post a picture of the broken clip(s) so I can give you some direction. I think I know what you mean but I'd rather give you a certain answer than a wrong guess.
loveMy850
Post by loveMy850 »
I looked I cant find any of the clips.
Can you show a picture of the trim panel and where the clips fit. I may be able to identify them for you with a part # if I can see where they go. Some of the rear panels are the same as the later V/S70's from 98-00 but still need to clarify which panel you are talking about.
Thanks,
loveMy850
Post by loveMy850 »
Ok I took pics but I have a deliema, I dont know how to post one, thought it"d be simple...
loveMy850
Post by loveMy850 »
    Im sorry I feel really silly Im just not tech savvy, but give me a wrench, that"ll work
    sleddriver
    Year and Model: 1998 V70 T5
    Has thanked: 11 times
    Been thanked: 13 times
    Post by sleddriver »
    My inner wagon hatch panel is removed for now. I fix it and the clips soon fail. Then it rattles like crazy. I removed it for piece of mind. My ultimate solution is to affix it with screws: Won't loosen nor rattle and will stand up to repeated tailgate closing.
    M1 10W-30 HM
    That is the famous falling off lower tailgate inner panel but the OP would appear to be talking about the upper portion I think that goes up around the tailgate window. Maybe I'm the one getting it wrong here.
    loveMy850, if you have the pictures loaded on your computer as .jpg images then they should be fairly easy to add on.
    Make sure you click on the 'Full Editor & Preview' button below the reply box. This then has a section below it in blue that has Options or Attachments. Click on Attachments and There then appears a little grey box with Add Files. Click on that and it will allow you to add picture files from your computer.
    When you add a picture is asks you to place it in line. Click the cursor in the place you want to add the picture then click on the Place in line box and it should add your picture in there. You will not see the picture just a line of info. If you want to check what you have done click on the Preview button below the box and you should then see any pictures you have added. You can then go back down to the subject box and add any more stuff or pictures.
    On completion hit Submit and it should add your question, dialogue and pictures.
    I have had problems with the pictures I have added using various software and it won't add them to the MVS web-site. I have had to copy the pictures and make copies in the Pictures section of Windows and then for some reason they add.
    Watch out for the Robot software as it has you going crazy verifying you are genuine. Follow the instructions and you should be ok.
    Good Luck,
    loveMy850
    Post by loveMy850 »
    Your a wonder N. In a good way ⭐yesterday I took pics I dropped dragged, did the file thing of all things my connect failed I was hopscotching, now I'm on my own data, other wise I may have gotten I will try because I need to know how, Thanks, anyway yes it is the infamous upper along the. Window, thinking about just ordering a kit and hopefully some fit.
    Has thanked: 1611 times
    Been thanked: 4073 times
    YEah - Matt has been promising drag and drop forever, but, like the elusive manual transmission, he hasn't been able to deliver..
