s60 16T upgrade without tuning
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
SantaFe75
Year and Model: 2003 s60
Has thanked: 16 times
Post by SantaFe75 »
Hey everyone,
I'm sure this has been asked and answered however, I can not find a conclusion.
I have an '03 2.4L LPT s60. I would like to install a TD04HL-16T that I have laying around.
I have heard that I can put the turbo in without having to tune it and, it will run better. I understand that if it is possible, I won't get the full potential without the tune. If I can run "no tune" will I see any noticeable gain?
At around $700 I can not afford a tune right now.
P.S. I would delete the cat when installing the turbo. Stage 0 complete.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
If you delete the cat, check engine light will come on.
If you just installed the 16T turbo and no other changes, you will not net more power than what you have now with your stock turbo. You may even add more boost delay into your system, as the ECU uses the MAF sensor to calculate the amount of air going into the engine and the ECU will allow boost up to a certain point. When it see the amount of air reached, ECU simply drops the boost level. So, adding bigger turbo will not allow you to have more air into engine, with no more air, you will gain zero.
So, why throw $700 away with ZERO gain?
85 GLH, 367 whp
00 Insight, 72 mpg
roccodart446
Year and Model: 1999 S70 GLT
Has thanked: 1 time
Post by roccodart446 »
If you delete the cat the engine light will come on, BUT...a simple 02 spacer will eliminate that or you can have it tuned out when you get your tune. Depending on what state you live in, it wouldn't matter anyhow, example, Florida.
The car will love a catless downpipe and so will you.
