Under normal driving conditions it drives very well but if accelerate hard it will hesitate/lurch for a millisecond and then full power comes back. It's also random which is annoying. It will do this in drive, manual mode and with traction control on or off. It happens at highway speeds as well and I have also noticed that it will kick in full power/boost and then quickly go to about 80-90% boost even with the pedal on the floor.
Wondering if anyone has had similar issues or there is a known repair for this. Maybe a transmission problem?
2001 S80 T6 hesitates for a few milliseconds during moderate/full accelreation Topic is solved
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
Mine had this sort of hesitation when briskly accellerating. A new TCV (turbo control valve) cured it. Was a ten minute job. May not be your problem but worth a try.
Yeah, I've been reading this as well. I will swap out the TCV and report back.Cees Klumper wrote: 14 Aug 2017, 14:34 Mine had this sort of hesitation when briskly accellerating. A new TCV (turbo control valve) cured it. Was a ten minute job. May not be your problem but worth a try.
2001 S80 T6 Moondust sent to auction for scrap
- June
- Has thanked: 523 times
- Been thanked: 261 times
Mine had your cars symptoms as well, also had surging every few seconds under WOT. TCV cleared everything up. JuneLegofan wrote: 14 Aug 2017, 17:24Yeah, I've been reading this as well. I will swap out the TCV and report back.Cees Klumper wrote: 14 Aug 2017, 14:34 Mine had this sort of hesitation when briskly accellerating. A new TCV (turbo control valve) cured it. Was a ten minute job. May not be your problem but worth a try.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
It doesn't surge it just stalls right after WOT and then back onto power.June wrote: 14 Aug 2017, 18:56Mine had your cars symptoms as well, also had surging every few seconds under WOT. TCV cleared everything up. JuneLegofan wrote: 14 Aug 2017, 17:24Yeah, I've been reading this as well. I will swap out the TCV and report back.Cees Klumper wrote: 14 Aug 2017, 14:34 Mine had this sort of hesitation when briskly accellerating. A new TCV (turbo control valve) cured it. Was a ten minute job. May not be your problem but worth a try.
- June
Mine also would fall flat on it's face pulling away from a light under moderate acceleration, like it would completely dump all boost 5 seconds into moderate acceleration only. It felt like I completely shut the engine off momentarily then hit the gas hard. I thought the ETM was failing but my mechanic at Volvo replaced the TCV and it fixed it. As far as WOT my mechanic used the word "notching" I figured surging better described it. Keep us posted on what the fix for yours ends up being. JuneLegofan wrote: 15 Aug 2017, 16:53It doesn't surge it just stalls right after WOT and then back onto power.
My Volvo cars owned
1996 960 ordered
1996 960 ordered
June wrote: 16 Aug 2017, 14:29Mine also would fall flat on it's face pulling away from a light under moderate acceleration, like it would completely dump all boost 5 seconds into moderate acceleration only. It felt like I completely shut the engine off momentarily then hit the gas hard. I thought the ETM was failing but my mechanic at Volvo replaced the TCV and it fixed it. As far as WOT my mechanic used the word "notching" I figured surging better described it. Keep us posted on what the fix for yours ends up being. June
Ah, ok, thanks. I will...
- 715 Views
- 1001 Views
Last post by SuperHerman
- 520 Views
Last post by oldtimertoo
- 863 Views
Last post by abdomar528
- 13 Replies
- 2507 Views
Last post by bronco
