EEEEEK.....GROSS....just when I thought I'd slain this dragon a few years back, she rears her ugly head once again. The gas cap is OEM Volvo with their nice seal. About one year old. I've cleared the code only to have it return...several times.
Off-the-top-of-my-head-what-hasn't-been-replaced: Gas tank top plumbing, fuel pump seal, fuel sender seal, J-hose on CharCan, big hose between tank and CharCan (vent hose?). PURGE & SHUT-OFF valves are relatively new (~6yrs).
I've never dropped the tank. The other day I had a thought though about using a truck inner tube to support the tank, then slowly letting the air out to lower it. Then the reverse to raise & support while hooking it all back up.
Her evil twin ABS is also back on for good. Not sure if it's the module (again) or the harness connector that's loose. Both systems have been a RPITA. I can't even remember when ABS has engaged. Haven't felt the brake pedal vibrate in a very long time. It used to do that on occasion when pulling out of the driveway for some odd reason. Testing?
Once more into the breech......
Return of the dreaded P0-455 GROSS EVAP Leak
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
M1 10W-30 HM
M1 10W-30 HM
- Has thanked: 311 times
- Been thanked: 817 times
I use a small hydraulic jack and a 1 x 6 board when dropping the tank. When near-empty it is pretty light and very easy to control. But I like your tube idea, clever!
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Stew -- J hose was culprit after my mechanic smoke tested for my P0455 gross evap leak in the '99 S70. Try the Occam's Razor approach before you drop the tank.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Be careful and don't run with Occam's razor
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Try squirting WD40 inside the purge valve, it cured mine. I think they stick occasionally.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- sleddriver
I built a smoker a few years ago. Looks like it's time to use it again.
J-hose: Frankly surprised mine has lasted this long. So many others issues were all solved by replacing it after finding obvious leaks. It may have finally gone tango uniform this time.
I'll give the purge valve a squirt. The seal could be dry. I'll squirt the shut-off valve as well.
M1 10W-30 HM
M1 10W-30 HM
- Has thanked: 316 times
- Been thanked: 531 times
That's interesting. Do you know if they're supposed to click? Both mine and my cousin's purge valves click pretty loudly, and we both have an occasional P0455 appear. Maybe this fix will work?mecheng wrote: 14 Aug 2017, 07:54 Try squirting WD40 inside the purge valve, it cured mine. I think they stick occasionally.
Funny this thread came up, P0442 popped up today. Oddly enough, without its best friend P0455. Car's running like crap again... I guess it had a good weekend after replacing the alternator.
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
If you have a 98 you may not have the J hose. The early 98's didn't have it. I spent an entire weekend looking for my leak and eventually I bit the bullet and took it to Car X and they smoke tested it for $65.
98v70dad
- Year and Model: 98 V70
- Has thanked: 1 time
I chased this for nearly a year and never paid much attention to the gas cap since I replaced it with an new one from the dealership because I liked the tether on it. After about a year out of total frustration I bought one of those generic caps from an autoparts store, carefully removed the seal and put it in my original cap. While I was at it I noticed that the top of the fill pipe had some sharp gouges in it so I burnished them out with fine grained sandpaper, cleaned off the dust, put the cap on and PO455 finally went away to haunt someone else.
- 1970 Views
Last post by sleddriver
- 214 Views
Last post by TroutJim
- 1619 Views
- 1410 Views
Last post by t3yf5g
- 876 Views
Last post by ovlov058R
