Greetings,
My 2001 V70 wagon was in an accident where the driver's side rear quarter panel was "gouged" thru the metal. The panel is being cut out and replaced. The body shop started the work by removing the rear glass. The upper (roofline) inside plastic trim was busted next to a screw attachment spot (screw not removed). The body shop claims the plastic was broken when the car arrived. I claim it was not, it's not even near where the outside damage occurred. My question: If you are removing the driver's side rear quarter panel glass, do you need to remove the inside trim before removing the glass? They say you do not, but I believe if you do not, you could potentially damage the inside plastic trim, especially with the tool they use to get under the rubber glass seal. The glass is out and the trim is broken (part is still screwed to the body), but they say they didn't break the trim. Any input from someone who has removed the glass, or done rear quarter panel replacement, would be helpful. Thanks.
Body/glass experts please chime in
- SuperHerman
- Been thanked: 207 times
If you have VIDA see what their instructions show is the proper procedure.
Although sometimes shops develop shortcuts by removing other panels they find easier - which could be your case. I know on two of my non Volvo cars I had to remove the outside trim to take out a rear window to get to the window mechanism. To create the space to get the window out the trim had to be removed - glass does not flex.
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
I'm sure I'll glue it, but I won't forget it. The body shop has had the car for a month and all they've managed to do is remove the window and break the trim. Not really what I was expecting from a professional outfit, hence my question concerning the proper removal technique of the window.
I'm looking forward to getting the car back. May be two more weeks before I see the end result and get to "glue" the trim back together.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Body shops working under an insurance claim are quite evil quite often. This smells foul enough I don't even need to ask/confirm that this is the case. If they damage something themselves they don't get reimbursed to repair it - call the insurers' claim center and complain (and cross your fingers they decide to side with you).
When I had a rear quarter replaced under an insurance claim a year ago (not my fault, the other person's insurer was paying) their insurer steered me to a body shop... put deep scratches in the clear coat on the opposite side quarter while pulling/reinstalling the rear window glass which I would attribute to sloppy/inadequate shop dress codes regarding belt buckles, watches etc. ...deep gashes which cant be hidden by product/waxes etc. When I picked the car up they said **nothing** and I noticed it a day or so later. I was so disgusted by the whole experience it wasn't funny.
- mrbrian200
Translated, open in new tab/window and scroll down to the post which is in Russian:
https://translate.google.com/translate? ... 6t%3D82344
It's an ad. Feel free to delete this post when you cleanse the site of these, Matt.
- 1075 Views
Last post by Lostriverwagon
- 2317 Views
Last post by Bob 88
- 775 Views
Last post by clifford06
- 2690 Views
Last post by Mr. Ray
- 1531 Views
Last post by IslandV70
