02 V70 Cabin fan and dash lighting problem
Norm_B
Year and Model: 2002 V70
Post by Norm_B »
Having a problem which I can't figure out with my 2002 V70. The blower for the cabin fan stopped working, and the dimmer switch for the dash lights/headlight control switch also stopped working. The climate control module was my first thought, so I swapped it out for a spare I had. No luck. All of the other functions on the ccm work (defroster, heat for the seats, etc), an the headlights turn on automatically at night. Fan is not jammed, I pulled it down and checked. I think the two problems are somehow linked but I'm just not sure where to go from here. Any thoughts?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Did you check the fuse?
Can you pull the codes, autozone with pull them for you free.
Norm_B
Post by Norm_B »
Checked the fuses, they were fine. No corrosion or anything. No codes that I can find with my scan tool. Going to try a new resistor see if that's the problem with the fan. The headlight control switch I may just replace. Can find used in eBay fairly cheap.
