Central electronic module
mnmk
Year and Model: V70 2004
Post by mnmk »
Hello. If I remove the CEM for inspection and disconnect the wiring harnesses will I have to have the CEM reprogrammed?
Thanks.
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
There is not correct question.
If you install back your original CEM after inspection, NO, not need program something.
If you going to replace CEM to another CEM, YES, you should reprogram replacement CEM.
mnmk
Post by mnmk »
Thank you. I just want to remove and inspect. I will be replacing the original back in the vehicle
carpenterbob
Year and Model: 2013 xc60
Post by carpenterbob »
I have one headlight out new bulb did not fix, when I pull the CEM on a 2009 s60 can I repair the it my self.
