Dear all,
My final problem is that all the dim off.
But it allways start witf abs and stabilisation problem that two problem problem lights on the dim write brake problem and after a few sec the speedometer tach and everithing fall down and all lihts of. Ome yars ago my dim had some problem unreadable text, runing time.... At that time the dim was resolder and ewerithing worked fine but now I do not know what coud be the problem.
Please help if somebody know this problem or have some suggestion how to fix it.
Thanxs znyakas
Dim speedometer abs fail
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
Can you confirm it? Can you text VIN?Year and Model: 2002
And like additional thing, for get info, can you make photo label from your CEM module?
Volvo electronic expert
Online Data Transferring Service for Volvo modules
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Try this:
Remove the control section (bottom) of the ABS unit. I believe it requires an E5 torx socket. E=external torx.
Look for bad solder joints. It effects many things you describe.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
That's how the DIM fails. Find a tv repair shop that work on the tiny SMD electronics,ask them to reflow the chips and check all small resistors on the board. keep the car battery disconnected when the DIM is out. Or check DIM repair service on ebay.
I have though. But try other way 3 days ago I have unconnected the connector of ABS modul and used the car without ABS system. The differences was only that when I start the car the abs lights on and there was no spedometer because of there was no comumication but all the other things worked on the dim for some km and after again the same situation everithing stopped working and all the dim off
