1998 V70 Leaking Transmission Fluid from Oil Cooler Connection to Radiator
StubZz
Year and Model: 1998 V70
Has thanked: 1 time
Post by StubZz »
Hello All!
I am new to this site, but I've come here before and seen some helpful threads!
My '98 V70 was leaking a lot of coolant recently, I decided to take it to a shop nearby that specializes in radiators and mufflers. After the replacement it was all good for a few days. Then it started leaking transmission fluid from the bottom transmission oil cooler hose connection. It is a slow leak, so I'm not too worried about it as of now. It was not leaking before the replacement. After the replacement the guy that worked on the car said we should get some new transmission cooling hose retainers, as the old ones were incredibly corroded (https://www.fcpeuro.com/products/volvo- ... er-6842411 <-link to the part on FCPEuro, part number is 6842411). I've also driven the car around for 30 minutes and checked the fluid oil (as per the instructions in the owners manual) and the fluid was at the max line if not above. Will the leak resolve itself after the fluid level has reached the max line, is it a problem with the radiator itself, or will putting the new retainers on resolve it?
Thank you for any help you will provide, it means a lot to me! :D
~StubZz
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
85 GLH, 367 whp
00 Insight, 72 mpg
StubZz
Has thanked: 1 time
Post by StubZz »
tryingbe wrote: 18 Aug 2017, 15:53 Replace them all.
https://www.fcpeuro.com/products/volvo- ... 0-6842411k
Alright, thank you!
Has thanked: 2207 times
Been thanked: 1852 times
Also be careful when fitting the hose retaining cage. They are orientated. If fitted the wrong way around they will leak and can blow off as a friend of mine found out the hard way!
Also, some cooler hoses not have 2 'o' ring seals not only one?
StubZz
Has thanked: 1 time
Post by StubZz »
scot850 wrote: 18 Aug 2017, 16:35 Also be careful when fitting the hose retaining cage. They are orientated. If fitted the wrong way around they will leak and can blow off as a friend of mine found out the hard way!
Alright, I will be careful with that! I am not sure about the 'o' rings, I believe it is one set for both though.
brunocerous
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
How did the cooler line replacement go?
I've been getting the same quarter-size fluid stain on our driveway since doing a drain-and-fill, and yesterday located the culprit: Leaking transmission cooler hoses where the rubber meets the metal crimp.
It's been getting worse, so I've got another project ahead of me!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
StubZz
Has thanked: 1 time
Post by StubZz »
brunocerous wrote: 17 Sep 2017, 05:33 How did the cooler line replacement go?
It went fine! I now have no transmission fluid leaking!
