1999 S70 5-speed to 6-speed conversion?
olpossum
Year and Model: 03 V70, 99S70
Post by olpossum »
Is it possible, or even desirable, to put a 6-speed manual transmission in a '99 S70 that has the factory 5-speed in it? Bought my kid one for college, and now she's moved on and I got hers back, which I like driving. It's still really good, I put a clutch, et al, in it last year,but it's geared sort of low, and I keep reaching for 6th, but there isn't one. Can't find anything about this on the internets, or here.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
http://volvospeed.com/vs_forum/topic/146516-m66-vs-m56/
I wouldn't, cost too much and gain too little. You'll need new clutch, new-used transmission, for around 7.5% reduction in gear ratio.
85 GLH, 367 whp
00 Insight, 72 mpg
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Probably easier to "donk" it out.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
j-dawg wrote: 18 Aug 2017, 21:04 Probably easier to "donk" it out.
That photo is disturbing! June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Clemens
Has thanked: 501 times
Been thanked: 228 times
Post by Clemens »
June wrote: 18 Aug 2017, 21:22
I totally agree
1996 855 R,
2010 V70 D5,
Has thanked: 2215 times
Been thanked: 1853 times
Back to what the OP was asking I have not heard of anyone trying this conversion.
First thing I would check is if the gear ratios of top gear make any point. I would say having owned 5 speed and 4 speed autos the 5 speed do seem to accelerate quicker through the gears, but once in top not sure there is a big difference, but never actually checked it.
The other issues would be you may have to change the axles also, the TCU of course and then would that work with your car.
It is an interesting idea, but maybe a manual swap would be easier?
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The factory fitted 4 speed autos to 1999 C70s so this must already be a manual being a 5 speed.
There would need to be a lot of homework done.
Sit down with the spec sheets and view them carefully. Some custom bits would be needed. I don't think space would be an issue. Personally I think it's a great idea.
Can you post up both manual 5 speed specs and 6 speed manual specs here so some of us can comment on whether it seems suitable.
tryingbe
Has thanked: 1 time
Post by tryingbe »
precopster wrote: 19 Aug 2017, 16:48
Google M56H and M66
85 GLH, 367 whp
00 Insight, 72 mpg
precopster
Spec sheets from the donor car that's donating the M66 and your own car are far more relevant than a google search. So many models use these transaxles and I bet with a variety of final drive configurations so careful choice of which model's specs match the 1999 C70s are key here.
olpossum
Post by olpossum »
Thanks for your replies, all of you. I'm not going to do it,I guess. The car has 258,000 miles on it, looks,drives,feels new,I do all my own work, but this may be a bit too much. I've started iffy projects like this before, and I hate more than anything to find out in the middle of one of them that it's not doable after all.
