Obvious Novice here with a novice question. Where is this part located? Replaced some things last week and when I went to put it all back together I realized I had this part that rolled away from everything else and can not for the life of me find where it goes. Go easy on me lol thanks
Bourgeois0424
- Year and Model: 1997 850 GLT
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Somewhere in the evap canister vacuum hose snake pit..
- misha
No abscate...it is located at FCPeuro.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2199 times
Abscate is correct in that it is part of the emissions pipework horror show.
If this link works, then it is item #22 in the diagram which may help you figure out what it attaches to:
https://www.volvopartswebstore.com/prod ... 86744.html
Interestingly, according to my version of Vida that part number is not fitted to an 850, let alone a 97 850 GLT (low pressure turbo).
When I look at the Vida layouts for the 97 850 GLT it does not list or show this part for your car (assuming the car is the one in your profile).
- Has thanked: 316 times
- Been thanked: 531 times
Volvo used so many different emission system setups, it probably was fitted at least one '97 850. I would assume a '97 GLT would be the same as my '98 GLT, but again, who knows.
My car has the rear charcoal canister near the gas tank. Assuming you have the front charcoal canister setup, look at the diagram Neil posted.
Bourgeois0424
The diagram was what I needed, got it reconnected. Tried searching for awhile for a diagram like that lol Yes this is the car listed in my profile. That is interesting though. Thanks a lot!
Look at Misha stealing your thunder
Well done figuring it out. Glad we were able to help you out.
- 1593 Views
Last post by quietlymknnoise
- 436 Views
Last post by vincentmb615
- 6641 Views
Last post by 2007volvos80
- 4224 Views
Last post by precopster
- 4523 Views
Last post by harrelldodd
