'04 V70 SUNROOF TO PARK POSITION
mayorpeoria
Year and Model: V70 2004 2.5
Post by mayorpeoria »
I have a '04 Volvo v70 and my sunroof has a rattle in fully closed position, I have tried to adjust the panel with the 4 screws holding it in place, and reset the memory with the full front and back position holding the button until it makes a reset motor noise. I don't know if there are any adjustments that I can do to make the back of the sunroof travel farther, closing the roof the glass panel moves forward like it should, and then the back of the glass panel should lift up to a level position, that where my problem is, you can push against the back and feel movement, and the sunroof is adjusted as high as I can, sticks up a little. thanks
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The rattle may well be from the sun shade. Have a look
viewtopic.php?f=9&t=49994&p=414872#p414872
mayorpeoria
I did remove the sun shade thinking there was something covered at the very back, still can wiggle the glass panel, but thanks for trying.
