So, on the XC 70... still waiting to see if electrical problems require the rebuild of the cem. We've noticed a whistling sound, mainly when accelerating, heavy on the throttle (not stomped to the floor... just a normal acceleration). It's seems like it'ssometimes louder when the wheel is turned, but I can't say that for certain. It's not steady... more warbly and low. If the radio was on you might not even hear it.
What things can I start to look for. I can't really remove the filler cap when I hear it, as it doesn't do it sitting still. It seems to me to be coming from in the cabin, but it certainly could be under the hood.
Thanks!
Minor Whistling 04 XC70
mikeamondo
- Year and Model: 04 XC70 - son's car
JRL
- Year and Model: Several
- Been thanked: 16 times
Pull out the dipstick a bit.
If the noise changes or goes away, it's a fully clogged breather
If not, I can't help you by reading about a noise
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As above, also search on Youtube 'pcv test'
I also have a hissing noise when accelerating heavier, haven't found the source yet, I wonder if it's related with a vacuum hose or even with the brake booster.
The power steering pump can also get noisy if it doesn't have the proper (green color) fluid
- 497 Views
Last post by jonesg
- 577 Views
Last post by 2012
- 424 Views
Last post by MrAl
- 795 Views
Last post by jenkinskg
- 815 Views
Last post by RickHaleParker
