1999 S70 Immobilizer ring problem? But no codes...
MathalomuleM31
Year and Model: 1999 S70
Post by MathalomuleM31 »
Hello everyone! So I have been having an occasional problem for about a year now when starting my 99' S70. From other posts I've been reading it really seems like the problem is my immobilizer ring. But I need advice...
The Problem:
(The problem happens about once in every 30-35 starts) I go to start her up, (RPMs go up) but she dies right away, if I keep trying and turning the key she cranks but wont start. But if I remove the key, put it back in the column, crank, then she will start. I know its not the Key because I have 3 of them and each one results in the same problem.
Here are 2 reasons why I am skeptical though and looking for input...
1. I don't get any check engine light codes when it fails to start. I've tried scanning when it wont start, by leaving the key in on the "on" (II) position and scan... nothing.
2. I can lessen how often this problem occurs... If I get in the car, put my key in and click it to the "on" (II) position, and wait about 5 seconds... Then crank it, I'm good. If I do this it starts right away (about 95% of the time) with no problem. On the other hand, if I quickly put the key in and immediately try crank it, that seems to "upset" :roll: her and make her not want to start. Doing this I get about a 40% chance of a successful start.
Also, after running the car, if I shut her off and then immediately try to start her again (keeping the key inside the column) she often wont start.
Any ideas? The problem seems to scream "Immobilizer ring!" But the "waiting 5 seconds to successfully crank" and "no codes" for the immobilizer makes me think something else like fuel pump?
Also could this be the symptom of a weak battery? My battery was tested a few months back as "weak". I don't remember specifically how it was "weak" but the guy recommended me getting a new battery before winter.
1999 Volvo S70 GLT 2.4 Turbo
Has thanked: 1609 times
Been thanked: 4065 times
That is exactly the behaviors of a bad key communication. Something is iffy and the antenna ring is most likely.
These comm problems don't throw codes usually
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
You may have slightly oxidized contacts at the ring.
'Wiping" the contacts by reseating them might help.
It's worth the easy job of pulling the steering column
cover to get access to the antenna ring, then just unplug
it and reconnect it a couple of times. Could clean'em up.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Buy a new one, cheap enough and easy to install
SeanyB
Year and Model: Volvo S70
Post by SeanyB »
Hey, know it's been a few years since the post but wanted to ask if you ever figured it out?
Running into the same exact issue with my Volvo S70.
