I am new to Volvo and to this forum.
2001 S80- engine light constantly on. But the folks at Valvoline Oil change shop could not find an error code displayed on their analyser. Does anyone have any idea as to what can be causing this?
Could the analyser not be the correct type or malfunctioning?
The battery tests Ok according to them. It has a new rating of 800 CCAmps and it tested at 626 CCAmps. Could this cause the engine light to be on without generating a code?
Thanks
Engine light but no error code found
- SuperHerman
- Been thanked: 207 times
Which light is on? Can you post a pic? It may be a service light and that will not throw a code. Other than that try a different scanner.
rb61
- Year and Model: 2001 s80
- Has thanked: 1 time
Could the fact that there is a missing fuel door lock mechanism create this situation? The cable/ connector is just hanging out inside the trunk trim cover.
I will try to find someone with a different code scanner and search the local salvage yards for a replacement fuel door lock
- good exercise at least.
Thanks
Thanks
- 748 Views
Last post by vtl
- 3396 Views
Last post by lawrencium265
- 3579 Views
Last post by FCPEURO
- 966 Views
Last post by rspi
- 17 Replies
- 5311 Views
