New to Forum, just bought '99 S70 AWD
amolnar0829
Year and Model: 1999 S70 AWD
Post by amolnar0829 »
Bought the S70 3 days ago after watching a bunch of Robert DIY incl. pre-purchase checklist did the glove test and case was sucking the glove. I was finding that these year white block cars last 300-500k miles with the maintenance kept up with. Reliable winter daily with some turbo fun was the idea.
I bought the '99 S70 AWD for $1300.
The GOOD:
1) Runs and drives, AWD works well
2) Viper remote start
3) Hankook winter tires 215/50-16
4) Pioneer Nav+bluetooth audio head unit
The BAD:
1) losing a .5-1 quart of oil every 500 miles from back of block some where looks especially wet with oil where a line connects to the turbo. Oil cap also has some blow by pushing oil up out the cap seal and its a new cap :o
2) Lower control arm bushings loose needs replace of arm
3) Outer tie-rod end has play in the joint/bushing needs replace
4) 10-20% throttle is inconsistent and jolts the car idle is mostly rock solid at 850 or maybe 900 with the A/C off but the car hesitates and jolts on cruise control even with A/C off
5) reverse feels weak
6) A/C clutch engages then disengages constantly about every 3 seconds when A/C on and no cold air (I tried zip ties to help the a/c clutch engage more but a couple people told me it may just need a recharge)
7) When A/C is on car jolts alot when sitting with foot on the brake in Drive
Do you think I got a good deal?
I'm trying to repair and stage 0 this beast before winter hits in a few months in MN.
2016 Fiesta ST - race car
1999 S70 AWD - daily and winter car... maybe get a tune on it one day
Has thanked: 1610 times
Been thanked: 4065 times
Welcome to MVS!!
The 1999 is the best year for V70s, you get a cool Italian throttle body that you get to replace every 100,000 miles or so for much less than you paid for your car. Maybe.
You do have some throttle body symptoms but first step is to pull plugs, check compression and report back how many miles are on this car, as well as plug condition - pictures best
The turbo oil lines are easy to repair with good Volvo gaskets - cheaper to use off brand but then you have to do them again in a year.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Welcome aboard!
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
The BAD:
Buy a new oil cap seal. Oil line O-rings and gaskets like Abscate said.
R+R the arms, you should have "4-bolt" A-arms while you have it apart do your tie rods, then get an alignment.
Look for a replacement ETM, used yellow label, or contactless.
treat it nicely, drain and fill trans-see threads for this process.
Do the bread tie/zip-tie fix
see the above.
Stage zero-smoke test and fix all the leaky vacuum lines. tune-up, see what changes.
Current Volvos:
