DIM (driver information module) illegible
docLocke
Year and Model: xc70 '04; '98 blend
Post by docLocke »
2007 XC70 standard OEM DIM poor design (front lit; no backlighting) makes it near-impossible to read, day or night. Anyone share the problem and find a solution?
I've not seen this issue raised (search finds DIM functional problems); begin to wonder if something wrong w/ my vision. Or maybe my DIM missing something.
Any wisdom welcome.
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
What about backlight from radio? The same? In this case replace LSM.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Do you mean, you can't read the messages displayed on the lower left corner of the instrument panel? This panel is back light but the bulbs can burn causing it to be almost impossible to read. Maybe have the bulbs checked - careful to have the car battery disconnected at all time while working on the instrument panel.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
docLocke wrote: 02 Sep 2017, 19:54 2007 XC70 standard OEM DIM poor design (front lit; no backlighting) makes it near-impossible to read, day or night. Anyone share the problem and find a solution?
Any wisdom welcome.
My 2004 is impossible to read when driving on sunny days. Very difficult to read, if it's due to bulb failure it can stay that way. At night or overcast days it's ok.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
If he has the watch dial gauges, the only light comes from above, a real dumb way of doing this but that's what Volvo did!
(Same as an R)
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
The analog gauges are lit from the front/top, however, the LCD message/odometer/clock/etc. portions are back lit. If you're having trouble reading these in the daytime then there is likely a bulb problem or as yagger noted possibly an issue with the LSM/dimmer control.
docLocke
Post by docLocke »
No problem w/ backlit LCD messages, ISO, etc. The analog dials (speedo, tach) are lit by LEDs from above; i.e., they're reflecting and nearly invisible.
I've had the cluster out, confirmed no way to mod. Wondering about swap--assume all kinds of nasty data issues involved.
And yes: lousy design it was. Is.
mrbrian200
Reflective glare off the dial face. I understand now. I wonder if a polarizing film might help.
