I have a code P0030 Heater circuit on front oxygen sensor. I had to get the code read at the local parts shop since my reader is kaput and I have no way of reading live data. With the heater circuit causing a cel will that shut down the 02 sensor all together and set the fuel mixture to a fixed value (open loop)? If I clear the codes it returns within the second restart.
2000 V70R
Heated Oxygen Sensor circuit failure
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
The heated oxygen sensor may not get hot enough to give a valid reading (one the ECU expects to see) if the heater on it no longer functions.
You should be able to check the heater circuit on the O2 sensor with a multimeter set for ohms (resistance.) If it is infinite ohms, it is toast... If it isn't, then it's time to check the harness, power supply to it, fuses, etc.
2023 Lexus RZ450e -66k
- 3027 Views
Last post by frisky99
- 3603 Views
Last post by jimmy57
- 1367 Views
Last post by brant
- 22385 Views
Last post by loveMy850
- 5736 Views
Last post by RickHaleParker
