Handbrake dash warning light won't go on Topic is solved
harojs
Year and Model: 850, 1996
Post by harojs »
1996 850 Wagon
- BRAKE bulb DOES light during pre engine start cluster bulb test
- BRAKE bulb DOES light when brake fluid level sensor removed
- BRAKE bulb DOES NOT light when handbrake engaged
- Handbrake continuity switch checks OK
- Grounding Handbrake yellow wire to chassis DOES NOT light bulb
Any ideas? Seen this before?
I can't find a good circuit diagram to chase the yellow wire route up from handbrake switch
Is there a computer reset required somehow?
-John
Bellevue, WA
[email protected]
p.s. - sorry just saw there was a previous post on this topic - oh well, maybe that will help get noticed
harojs
Post by harojs »
OK - FIXED
There are TWO break warning bulbs in the dash - BRAKE and PARKING BRAKE
I had assumed the BRAKE bulb was for both the break fluid level and the parking brake, and I started down the path to debug the switch on the hand break and got wrapped around the axle.
Since the PARKING BRAKE was not lighting up on start check, I didn't see it light up, and so did not remember there are two bulbs.
Hopefully, someone will find this post if it happens to them.
Thanks for watching - John.
