Im diving into the clutch on my P2 - 2005 V70 NA
The VIDA has a boatload of special Volvo tools and engine holders for this job
Has anyone done one on a P2 - am I headed for a pig in a poke?
Im not jimmy, but Im a decent wrench turner. Not my first engine out or transmission out.
Im planning on doing it on tall jack stands.
P2 Clutch pressure plate flywheel release bearing slave cylinder - 2005 V70NAM56 clutch subframe engine drop Topic is solved
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
For the clutch job itself, the UK guys really have the expertise, most of their cars are manual down there http://volvoforums.org.uk/
A touchy job, and not to be done twice
JRL
- Year and Model: Several
- Been thanked: 16 times
You need something to hold up the engine and a helper to line up the tranny assy on re-assembly but it's doable
01_Nautic_V70
- Year and Model: 2008 XC90 V8
- Been thanked: 8 times
You can use some simple lumber for the bridge to hold and lower the engine.
I used a jack and ratchet strap to raise the trans back into position. Presumably the manual is a fair bit lighter.
There is a lot of kerfluffle about releasing the clutch pressure plate from the flywheel with special tools, not sure if that's a stopper for me
I'm going to do , flywheel, hydraulics , plate, and disc while I'm in there
Searched the UK forum and couldn't find any joy - have a break this afternoon and will try again.
Still haven't made the call on this one. Im 50-50.
Pros
I can do the wheel bearing and evaluate suspension while doing the job
Experience
Abby is home for a week to help
Weather is perfect
Back up at indie I like is three weeks - I can be done before then
We got NOTHING here on MVS and that should be changed..
Cons
Will I mess up engine dropping and get in deep trouble - I guess worst case is push to street and call AAA for clutch failure - is that ethical/Moral or does that make me Martin Shkreli?
Stealing 2 hours a day from spouse on weekend
(on edit by Ms Dr Abscate - this should be in the Pros column)
Pros
Experience
Weather is perfect
Cons
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Are these the instructions you saw in VIDA? (auto trans shown but probably much of it is pertinent to your manual trans.)
http://www.v70xc.com/0/resources/how-to ... Remove.pdf
http://www.v70xc.com/0/resources/how-to ... nstall.pdf
Maybe you can fabricate an engine hanger (truss).
jbeebo
- Year and Model: S60, 2005
- Been thanked: 4 times
did you see the truss that Nautic rigged up? Nicely done.
viewtopic.php?f=9&t=75588&p=447534&hili ... ck#p447879
2005 S60 2.4L (B5244S6), 175k miles
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
A hack like me did one not long ago, so you'll be fine. I recall that a ratcheting come-a-long (or two) was extremely helpful in maneuvering the hunk of metal. It is however much lighter and smaller than an automatic trans.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Well, I think I may have really driven this bad clutch past prudent practice.
I'm dropping the subframe, and all the pieces of the release bearing are pouring out of the week hole.
Lots of little ball bearings
