Starting Off in Second Gear Intermitantly? Why
warmblood58
- Year and Model: 1989 245
- Has thanked: 5 times
- Been thanked: 2 times
On my AW 50-42LE transmission (95 T-5r) What would cause car to take off in second gear versus first other than winter mode? Any thoughts? Thanks!
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
When does that happen? Always or only when the tranny fluid is hot (first stop and go after long highway cruises, city fraffic, stop and go conditions)?
Has the tranny fluid been changed recently? If the fluid looks nasty change it again.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
warmblood58
Thanks! I would say after warm- trans just flushed completely. Might be stuck in winter mode though I understand that is a 3rd gear start. What would a hot fluid warmed up second gear start indicate?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
When you say flushed - did they power flush it?
Did you have this issue prior to the flush?
If answers yes & no, then likely they lodged something in the solenoid or passage.
warmblood58
Not power flushed, disconnected line and added fluid until it flushed clean. It appeared that previously, this car had an external radiator leak and a internal leak resulting in coolant mixed with ATF though minimal. I will pick up car Monday and drive it about an hour and should be able to discern more after driving. Thanks!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Running coolant in the transmission will usually destroy it. Check the level PROPERLY before you drive it.
- rspi
Contact rspi..
- 457 Views
Last post by June
- 4776 Views
Last post by wizechatmgr
- 605 Views
- 2823 Views
Last post by xHeart
- 1383 Views
Last post by RigsPGT
