The other day I checked the ATF level on my 96 R and discovered that it was a bit low. The strange thing is that the color of the ATF was neither red nor dirtyish brown but rather clear. I had replaced it two years ago and do an additional drain/refill once or twice a year. The fluid still smells like ATF, but the red seems to be gone. Sincr I was a bit low on fluid and it still smells like ATF I am ruling the chance of radiator/tranny cooler leak out.
I've always used Mobil ATF 320 which covers Dex 3G.
Is it normal that the ted color disappears before the fluid turns nasty brown?
ATF not red anymore? Topic is solved
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Sounds like ATF where the dye just gave up the ghost. I've seen this in my commercial trucks as well... Last time I questioned our fleet mechanic he said to not worry about it.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
thanks, now I can go to bed happily...
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 12 Replies
- 2503 Views
Last post by kawish
- 942 Views
Last post by voom8
- 26 Replies
- 5502 Views
- 11 Replies
- 11685 Views
Last post by STSCowboy
- 1785 Views
Last post by RickHaleParker
