Why the XC90 Cigarette Lighter Blows Fuses
I posted this as a statement but its actually a question. This seems to be a very common problem with the XC90. My year is a 2009. I have removed the panel with the radio and installed a brand new Aux Power Point/Cigarette lighter. Two purple wires soldered into a new power point unit. It is not the fault of a bad cable being plugged into the socket nor is there a penny or any other item stuck in the socket. It is new. The rear socket in back works fine. But the front and middle seats power sockets blow the 15 amp fuse constantly. If I unplug the battery and take radio out and jiggle wires and put it back together it will work for a little while then BAM blows a fuse. WHY ?!! The large purple wires in the dash look just fine . If nobody can give me a good answer I am going to hard-wire my very own wires to the battery with my own fuse to stop this madness. Thought I would check here in this forum first. There are many questions on the internet on this very problem yet no answers. If anybody has a clue I would be more than grateful !
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Could have a look at the wiring diagram http://www.volvowiringdiagrams.com , might even be helpful for troubleshooting and in the odd event you decide to re-wire" the sockets directly to the battery. Would be interested to understand what drove the socket replacement in the first place, was the short there before replacement or only after?
Good luck !
** Noted added: Not sure how this gets to be a "common" problem, have two XC90s (12 years and going on my '05) and never come across this issue. Ever. **
Good luck !
Points to either a soldering fault or a bad plug. If it’s not a Blue Sea or other reputable sourced brand it’s likely an OBQ issue ; semiconductor industry speak for “ cheap junk”
- 819 Views
Last post by swedet17
- 2574 Views
Last post by alschnertz
- 1781 Views
Last post by BEJinFbk
- 930 Views
Last post by Tabbrod
- 1851 Views
Last post by ZootAllures
