1998 Volvo S70 Aftermarket Catalytic converter CA CARB
DoggyB22
Year and Model: 1998
Post by DoggyB22 »
Anyone know/recommend a CA legal catalytic converter for a 2.4L 1998 Volvo S70? Part # & website would be appreciated!
Has thanked: 1611 times
Been thanked: 4075 times
You probably need Volvo to pass CARB, available from FCP. ABOUT $1000-1200 plus core.
Has thanked: 2211 times
Been thanked: 1852 times
I know the US has some weird rules around use of used cats (makes no sense other than to stop steeling them) as they either work or not.
If you are allowed to buy and fit used, you have a huge Volvo and Saab specialist junkyard in vandsautodismantlers in the Sacramento area. They are good to deal with.
Unless you have a connection you will have a hard time getting a scrap yard to sell you a cat in the US.
I bought one from a member here, and then dropped my cat the next month.
Good karma..
DoggyB22
Post by DoggyB22 »
Thanks for the info guys! So... Would any one these work? Volvo isn't passing smog because apparently the current cat isn't CA legal anymore? & not worth paying $1k+ for a catalytic converter
http://www.partsgeek.com/catalog/1998/v ... erter.html
If the sell it as CA legal then they have hD it ' certified ' by CARB and it should pass.
It would be best to have someone from CA who has used it confirm they have passed smog.
$150 is much nicer that $1200!!
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
California may be the most strict in the entire USA when it comes to emissions. If it were me, I'd ask around at any local Volvo specialists you can find - odds are they know of a source that is local, will work, and is also compliant.
Any idea what the emissions code is for your vehicle? I can't remember if it is part of the VIN or the build plate by the battery. If I get some time this weekend, I may be able to dig deep for you.
2023 Lexus RZ450e -66k
DoggyB22
Post by DoggyB22 »
abscate wrote: 21 Sep 2017, 04:25 If the sell it as CA legal then they have hD it ' certified ' by CARB and it should pass.
I know right! Definitely not worth paying $1200 for a damn catalytic converter! But I guess Ill have to look into the Bosal converter.
DoggyB22
Post by DoggyB22 »
wizechatmgr wrote: 21 Sep 2017, 04:47 California may be the most strict in the entire USA when it comes to emissions. If it were me, I'd ask around at any local Volvo specialists you can find - odds are they know of a source that is local, will work, and is also compliant.
Yea CA sucks.... I mean there is ways around the whole "smog issue" but would like to just pass the legal way. But I don't know the emissions code. Anyone know how to find that out?? Would be much appreciated
Did you fail smog on the test or on the visual inspection?
One of the reasons the CA economy has flourished is because you can breathe the air, unlike the 1970s
