Ignition source for boost gauge light 98 v70 t5 Topic is solved
turtle1615
Year and Model: 1998 v70 t5
Has thanked: 2 times
Post by turtle1615 »
I'm installing a Bosch boost gauge and need to find a 12v ignition wire but don't have access to a wiring diagram any help? Can be for headlights or just plain key on voltage. Would I be able to tap into the CD player wiring? it's aftermarket.
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
You really have a couple options here.
You could use the dimmer line that comes out of the back of the dimmer switch. You could use a line from the radio.
2023 Lexus RZ450e -66k
turtle1615
Do you know what color wire to use from the dimmer switch?
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
You can access the dimmer's output from accessory connector.
Read through this post and you should find all that you need:
viewtopic.php?f=1&t=80795&start=20
The magic color for dimmer illumination is PINK.
turtle1615
That is exactly what I needed thank you!
