Brake Booster Check Valve Hose Question
warmblood58
Year and Model: 1989 245
Has thanked: 5 times
Been thanked: 2 times
Post by warmblood58 »
Hello All! From brake booster/check valve on the turbo cars, where does the other end of the booster vac hose terminate/ connect to and also, why is such a cheap little plastic check valve/grommet so damn expensive at 50.00 plus dollars??? Thanks!
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Assuming yours is like mine - it works through venturi effect of pressure passing past it at a designated rate, creating a vacuum, similar to the cheap fertilizer injectors that were long ago used at residential properties.
Mine is black and about 2-3 inches long. It has one connection to intake manifold and two out - one of which to brake booster.
Why on the price? It is Volvo. That part may only need to be replaced every 15-20 years - if ever. When you figure the cost per mile it is likely costing you less than what you are likely to pay for a single bar of soap on a yearly basis.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
warmblood58 the junkyard is your friend on this one, I have not seen those go bad and wouldn't hesitate to get a used one and save about $48.
Has thanked: 2197 times
Been thanked: 1850 times
They do go bad but not a common issue. /but like the guys say, the one that went out on me was 16 years and 165,000 miles on it.
Junkyard is your friend. Usually went I pull them at PnP I have pulled other parts and they don't charge me for them.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Thank you for the description wizechatmgr. What are the symptoms when this check valve fails? All three of my turbo P80 s have this valve but I have never given this valve any thought.
wizechatmgr
Likely an increase in the amount of pressure having to be applied to the brake pedal.
Post by erikv11 »
If the check valve isn't working, the problem will be air gets into the master cylinder. So the usual symptoms there: hard pedal (excess pressure in the master cylinder), or soft and spongy pedal with reduced braking in response to pedal travel (air gets into the brake lines).
warmblood58
Thanks all, yea, I was thinking about picnpull as I drifted off to sleep
warmblood58
Thanks all, yea, I was thinking about picnpull as I drifted off to sleep. When I go, I usually pull other parts along with certain bolts, clamps, nuts and other hardware -
