2008 v70 Hood Latch Sensor
martyrl
Year and Model: V70 2008
Post by martyrl »
2008 v70: I has a shop replace the radiator and now the 'Hood Open' message is on continuously. It appears the sensor is bad - since I can pull the wire from the sensor (but can barely see it), jump the connection and the message goes away. However, I can't find the part on any diagrams? Does anyone know the part #? Or is it built into the lock assembly? On both sides?
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Driver's side latch has the hood switch. Are you really concerned with underhood theft or forgetting to close it? Jumper it and end the problem.
martyrl
Post by martyrl »
Actually - the wire connector is on the passenger side - but I think you are right - probably not worth the trouble replacing...
jimmy57
Post by jimmy57 »
I was picturing P2 in my head. That makes sense as P3 has a major connector next to RH frame rail down below that latch that goes inside to the CEM in the RH bulkhead/footwell. CEM watches the latches.
thomlep
Year and Model: 83 244 GL
Post by thomlep »
Hi Martyrl, I have the same problem. Did you jumper the wires to make the problem go away?
'83 244 GL
previous '82 240 DL, '98 S70, '95 850
Has thanked: 1610 times
Been thanked: 4068 times
Middle age thread, but OP did jumper latch connection successfully in first post, for reference
