Crank position reference sensor resistance
PS78
- Year and Model: 2000 S70
- Has thanked: 2 times
- Been thanked: 3 times
Hi everyone, 2000 S70 base 155k miles. Recently had mil activated, pulled code P0339 intermittent signal for crank position sensor, shortly followed by P0336 circuit range/ performance for the crank position sensor. Driveability suffered noticeably on the return home. Car was very sluggish, and lurched occasionally. I disconnected the crank position sensor and checked the resistance. Reading was 133 ohms. My question is, is this resistance value in the correct range, and also if it is, is there a possibility the sensor could still be intermittently malfunctioning? The sensor appears original, has Volvo stamped on the sleeve and denso on the plug. Visibly it appears in good condition. Wires are intact and pliable, connections solid and sensor itself isn't marred, dirty, or damaged. I'll also add that when I removed it that the wire itself wasn't in proximity to other electrical wiring that would interfere. Any insight is appreciated thanks -Paul
Always first off the line, while all the cool people are still staring at their phones.
- Been thanked: 4069 times
Might be able to send you a used one to try if my college kid comes home this weekend? Are you near Bryn Mawr?
- Has thanked: 311 times
- Been thanked: 817 times
That resistance would be low for a 93-98 sensor (spec is 300 +/- 40 ohms), but I don't know the spec for a 99-00.
I haven't tried this but it looks like a good test: http://www.pelicanparts.com/techarticle ... esting.htm
PS78
I'm not unfortunately. I appreciate the gesture all the same thank you.abscate wrote: 26 Sep 2017, 19:27 Might be able to send you a used one to try if my college kid comes home this weekend? Are you near Bryn Mawr?
Thanks for the link. After the a/c voltage test I can confidently pronounce this sensor inoperable. I guess it gave its all for almost 18 years. I'll be ordering a replacement. Thanks Abscate and Erik.erikv11 wrote: 26 Sep 2017, 21:14 That resistance would be low for a 93-98 sensor (spec is 300 +/- 40 ohms), but I don't know the spec for a 99-00.
- 13 Replies
- 1510 Views
Last post by XavierEduardo99
- 23 Replies
- 2592 Views
- 14850 Views
Last post by precopster
- 2947 Views
Last post by MarcM
- 740 Views
Last post by Joegrent
