You can make Seafoam treatment much cheaper than buying it.
This is the reference I used but to simplfy it and give you more info:
Typical Seafoam application is 473mL
Therefore for a 4:2:1 ratio
270 ml Diesel
135 ml Coleman Camping Fuel
68 ml 99% Rubbing alcohol
The Diesel lubricates the fuel pump and valves. The Naphtha (Coleman camping fuel / aka White Gas) is the detergent. The rubbing alcohol removes water in the system (not sure this is vital in all cases).
The idle in my car is very smooth now and it seems a bit more peppy. Make sure you add it to a full tank of gas.
http://hildstrom.com/projects/seafoam/
Homebrew Seafoam
DIY Homebrew Seafoam
- 598 Views
Last post by Ozark Lee
- 11 Replies
- 2817 Views
Last post by MarcM
- 2105 Views
Last post by mecheng
- 1014 Views
- 39 Replies
- 5952 Views
Last post by DanelleNavarro
