S40 CPS code PO339
wilsonrcjr
Year and Model: 2002 S60
Post by wilsonrcjr »
I rebuilt my daughters S40 non turbo 2005. When restarted it will run for 10-15 seconds and stall. Codes intermittent Crankshaft position sensor. I replaced the sensor, & the connector. I sent it to a repair shop and they had problems communicating with the computer and told me to take it to the Volvo dealer. After 5 hours of diagnostic fees, they said it needed a computer and or flywheel. So, I brought it home and had Xemodex redo the ECM and I put in a new flywheel. There is no change, cranks, dies. The Volvo mechanic and I both checked the harness - there is continuity at the ECM pins for the CPS. Any ideas would be appreciated.
wilsonrcjr
I replaced the engine wiring harness today - still no improvement
runs for 10-12 seconds and codes crank sensor
any ideas would be appreciated.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Make sure the battery is not weak...strange things happen with our cars when they are.
