Time to replace automatic rear view mirror
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
I found several how to vids, and I have the replacement that I pulled. But do I need to remove the assembly from the car, or is it possible to replace the mirror while the assembly is in the car? Battery disconnected, of course.....
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
Need to remove it from the car unless you can solder in place. I did mine on a work bench. Once reinstalled, it's worked fine for the last 5 years. This repair isn't for everybody, but much cheaper than going to the dealer.
Good luck.
Good luck.
azureblue
I can solder in place. It looks like I can release the connector through the little hole in the bottom of the housing with the unit in place.. That step seems to be the hang up. Thanks
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- 642 Views
Last post by Lucky_Seven
- 1137 Views
Last post by phils94850
- 1015 Views
Last post by jimmy57
- 826 Views
- 1709 Views
Last post by 2004VXC90
